- 19 Dec 2003
- UK
cymatty said:Take it Ballistix isn't the most reliable of memory then?
Soul Rider said:It's quite amazing that nearly all the Ballistix RMA's are running on DFI boards.
Is this down to Crucial or DFI?
Ashcrapper said:my thoughts are get rid of them as quick as possible.
Dutch Guy said:Errors in tests 1 -4 are usually VCore or HTT(FSB) related, maybe the warmer ambient temp is the cause of the instability?
hmmmmm, looks like you tried everything possible, mind you I'm not surprised it is the memory that is failing, it's just a little strange that it fails at test 1 -4 and not test 5 or 8DrSteve said:Have tried tinkering around with all my settings. Dropped the CPU multi so it was at stock and also tried underclocking it. Have tried various HTT and divider settings. Have upped the vcore to over 1.6 (watercooled). Also have a great big 120mm fan aimed straight at the memory.
Did you buy from Crucial direct? If so get a refund and get some new stuff, otherwise contact the place you got them from and say you want something different. The fail rate on this rubbish is ridiculous.DrSteve said:hehe RMA request sent![]()
Dutch Guy said:hmmmmm, looks like you tried everything possible, mind you I'm not surprised it is the memory that is failing, it's just a little strange that it fails at test 1 -4 and not test 5 or 8
Ashcrapper said:Did you buy from Crucial direct? If so get a refund and get some new stuff, otherwise contact the place you got them from and say you want something different. The fail rate on this rubbish is ridiculous.
