First of all, wdnsr had a fuse box malfunction so the answer is he didn't manage to run all those rigs. He is also having problems running them all currently. Secondly, just because something works doesn't mean it's ok. You could run a domestic shower with 2.5mm cable... But you could also fry an egg on that same cable when it's running, and showers don't run 24/7 like your mine will!
Post or PM me the quote if you don't mind. I honestly can't get into what I would do it for because I haven't worked out what you need yet.
You still haven't told me what heats, cooks and cleans in your house, gas or electricity? Will also need to know if your cable head fuse is 63A or 100A.
As for the actual draw of each rig, this is being debated a bit here. There's one easy way to settle it, build one of them and plug it in via a current metre and it'll tell you to the exact watt. I can link you to a cheap current metre if you don't have one already.
I'll post back with some sums on worst case scenario load based on what you have told me so far.
Emailed you
E: Damn no trust lol.
