Motherboard upgrade - Which M-ATX 8700k (9900k)
The MSI insider livestream featured a couple of new mATX boards on some slides.
MSI MPG Z390M GAMING EDGE AC
MSI MAG Z390M MORTAR
It is not clear from the image if the EDGE has an 8+4 power connector for the CPU. The MORTAR clearly just has a standard 8-pin.
True. Seemed to have wasted internal headers on USB 2.0
  1. 1 x USB Type-C™ port on the back panel, with USB 3.1 Gen 2 support
  2. 1 x USB 3.1 Gen 2 Type-A port (red) on the back panel
  3. 6 x USB 3.1 Gen 1 ports (4 ports on the back panel, 2 ports available through the internal USB header)
  4. 4 x USB 2.0/1.1 ports available through the internal USB headers
Better picture of the MSI MPG Z390M GAMING EDGE AC. 8+4 pin CPU Power. USB looks to be the same as the Z370M Gaming Pro.
I think this is the complete mATX list now. I'll add the MSI links once they are available.
ASRock Z390M Pro4
VRM: 10 phases? [8 pin]
https://www.asrock.com/mb/Intel/Z390M Pro4/index.asp
ASUS Prime Z390M-PLUS
VRM: 8+1 phases? [8 pin]
https://www.asus.com/Motherboards/PRIME-Z390M-PLUS/
ASUS TUF Z390M-PRO Gaming
VRM: 8+1 phases [8 pin]
https://www.asus.com/Motherboards/TUF-Z390M-PRO-GAMING/
ASUS TUF Z390M-PRO Gaming Wi-Fi
https://www.asus.com/Motherboards/TUF-Z390M-PRO-GAMING-WI-FI/
ASUS ROG Maximus XI Gene
VRM: 10+2 (5 phases across 10 stages) [8+8 pin]
https://www.asus.com/Motherboards/ROG-MAXIMUS-XI-GENE/
GIGABYTE Z390 M Gaming
VRM: 10+2 (10 doubled from 5 phases with current balancing) [8+4 pin]
https://www.gigabyte.com/Motherboard/Z390-M-GAMING-rev-10#kf
MSI MAG Z390M Mortar
VRM: 8+1+1 phases (8 doubled from 4 phases) [8 pin]
https://www.msi.com/Motherboard/MAG-Z390M-MORTAR
MSI MPG Z390M Gaming Edge AC
VRM: 8+1+1 phases (8 doubled from 4 phases) [8+4 pin]
https://www.msi.com/Motherboard/MPG-Z390M-GAMING-EDGE-AC
Depends on what you are looking for. All apart from the Gene will offer you more expansion options than your Z370i. The Gene however looks like it has the best power delivery. Others vary by the quality of the on-board sound, Wi-Fi, RGB etc. and their overclocking capabilities.
Gigabyte matx , cheaper and 12 phase ( 6 doubled - 2h/2l) set up . 650amps plus across the VCore .
Mem won't clock as high as Gene but save small fortune, 4 dims being the main issue but allows cheaper none stacked kits to hit 64GB
And can run AVX without throttling
My basket at Overclockers UK:
Total: £140.45 (includes shipping: £10.50)
8+4 pin unlike MSI boards​
Gigabyte matx , cheaper and 12 phase ( 6 doubled - 2h/2l) set up. 8+4 pin unlike MSI boards
The Gigabyte mATX is 10 doubled from 5 for the CPU + 2 for memory/chipset. It does have a good VRM, it is just a shame that they skimped on the audio codec.
Midrange MSI boards (MPG) do have 8+4 pin, ALC1220 and SLI. They also come with Assassins Creed Odyssey which you can sell for £28, effectively making the mATX board £130.
ah apologies , forgot the Gigabyte boards were 2 down from Aorus - shame :(
