Heh. This is where my head is at... I am slowly looking at getting back into PC gaming and am re-exploring every bit of PC building (my last built machine was a Q6600), but stuff seems so outrageously powerful now it I don't know if I'd see much point teaching my kids how to overclock.It wasn't maintenance that caused me to switch back to air after over 17 years on water, it was the fact that it's become pretty much pointless unless you have a stupidly hot running cpu such as the 14900k which can be tamed by a much cheaper AIO anyway. Overclocking is as good as dead which was one of the main reasons to go with water. Yes, you will see lower temps but air coolers are not that far off these days for a tiny fraction of the price. Then there's the cost, over £100 for a gpu block everytime you change cards. Want the latest cpu block, that's £80+ for the best blocks, rads aren't too bad these days but pump and top or pump and res is well over £100 now. Unless you go second hand then you won't get much change from £500 for a decent set up all for a few extra degrees less. What's the point when a £30-40 air cooler gives very good temps?
Let alone watercooling! I still have my old case and a leftover single radiator upstairs... I can't see that ever being used again, however.
The tinkering is why I bother yeah. The practical benefits have mostly gone, other than the quietness which I have grown very used to.I always thought custom loops were a hobby that people did for fun? Surely the huge benefit is that you enjoy building it and enjoying cleaning it.
Yet everyone is moaning that the practical benefits are no longer worth it. I didn't realise they were ever practical.
Also, it was more beneficial to GPUs lately, but last gen oversized coolers helped a lot. There’s the issue with GPU size now, but most coolers are more than enough.The tinkering is why I bother yeah. The practical benefits have mostly gone, other than the quietness which I have grown very used to.
I think this probably goes hand in hand with the age thing.I always thought custom loops were a hobby that people did for fun? Surely the huge benefit is that you enjoy building it and enjoying cleaning it.
Originally it was for getting every last bit of performance out of your system. Back then it was possible to get anything up to double the speed of your cpu if you could control the temps. My first Core2Duo was a E4300 from when they first launched in mid 2006. It's stock speed was just 1.8Ghz but by overclocking the FSB it easily ran at 3.6Ghz 24/7 under water. Massively increasing the FSB was the very peak of overclocking back when the gains were actually worth all the tweaking unlike now when CPU's are already clocked to within a inch of their lives straight from the factory. GPU's were also worth overclocking back then. I had a AMD/ATI Radeon 5850 with a universal block and heatsinks on it and that was the best overclocking card I have ever had with it hitting a whopping 2Ghz on the memory and 1Ghz on the core. Nowadays it's all about undervolting the gpu to lower the obscene power draw that todays cards have which also lowers temps and allows the card to boost higher and for longer. Watercooling is now more for aesthetics rather than for performance gains and money that would have been spent on water cooling is better spent on better components.I always thought custom loops were a hobby that people did for fun? Surely the huge benefit is that you enjoy building it and enjoying cleaning it.
This happened sooner than expected. Sold my factory block GPU and bought an air cooled 3080 from a mate for a very good price. Decided to drain the loop and remove it all.When I finally replace my 10700k with an AMD setup, I'll also upgrade my 3080 to something, and I'll be going back to air or AIO.
You did exactly what i did. no more noise than my custom loop and much easier to change parts and clean the system as and when needed.This happened sooner than expected. Sold my factory block GPU and bought an air cooled 3080 from a mate for a very good price. Decided to drain the loop and remove it all.
I had 3x intake fans + 360 rad at the bottom, and 3x exhaust fans + rad at the top in an OM11D-XL. I did get occasional lock ups, not entirely sure what caused it but I am suspecting ambient air in the case being too hot.
I've now got 3x intake fans at the bottom, 3x intake fans at the side, and a 240 Corsair AIO at the top (which I'm borrowing until my AMD kit turns up). I'll be moving to a 360 AIO on the new setup.
So far I'm very pleased. CPU & GPU temps around 60-65 in games, no lock ups so far, and no change in noise levels. No regrets, the case looks cleaner in terms of aesthetics. And swapping out components is going to be considerably easier.
Edited to add that I did consider an air cooler for the GPU, but I think I'm restricted in my case with height, and it would have meant buying 3x more fans and another Corsair Commander.
I really enjoyed building mine but it was done with the intention of overclocking hard, the hardware just didnt have any meaningfull headroom though so now i just have a massively overkill cooling system and a massive case. not sure i would do it againI always thought custom loops were a hobby that people did for fun? Surely the huge benefit is that you enjoy building it and enjoying cleaning it.
This is a thread for those moving away from water cooling mostly, so it's never a necro thread at that point.Just having a nosey on through when I found this thread... Hope this isn;t too much of a necro revise
I went down the watercooling route many years ago and it's been a pleasure as I've gradually upgraded my fixings to quick release bitspower etc. I have found that the cost of the blocks has gone up so much in the past 4 years that upgrading my 2080 ti (I think?) to a more recent gpu is prohibitively expensive, so I've switched to gaming on an Xbox series x instead. I really would love to renew my system, but I just cant afford to, and quite frankly the time I have off from work nowadays it's easier to just power-on the Xbox and give Madden a blast.
My Plex/media storage server is an older PC, and I've got that fully watercooled with a R480 blocked up mining. I know it's costing more than it's generating, but it keeps my office nice and warm![]()
It used to be about the silence. I now game in silence using an AIO and air for the GPU. No need to do water changes, loop replacements. And if I want a new GPU it takes 5 minutes. I have zero regrets.For me custom watercooling has always been about the silence, i don't use headsets or loud volume from speakers. i currently game on a 13700k and 3070ti and can sit here with the fans on 20% (silent wings pro 4) and can game in pretty much silence with great temps. As for maintenance once every 2 years a fluid change is hardly much effort and takes about half hour. if your pipes are yellowing a soft tube replacement takes a couple of hours at most.
i think your version of silence and mine would be very different, i've fitted quite a few AIO's for people from 240's upto 420's and all have been noisy once they start getting a bit of heat soak, i found my 3070ti TUF to be too noisy but i also can't stand the noise from mechanical HDD's so for me it's a necessity, my kids pc is fully air cooled and it drives me mad walking into their room and hearing it.It used to be about the silence. I now game in silence using an AIO and air for the GPU. No need to do water changes, loop replacements. And if I want a new GPU it takes 5 minutes. I have zero regrets.
