OK more modern information regarding multiple GPUs.
The fourth lesson: Multi GPU (SLI/CrossfireX) is ******* complicated. You cannot begin to conceive of the number of failure cases that are involved until you see them in person. I suspect that more than half of the total software effort within the IHVs is dedicated strictly to making multi-GPU setups work with existing games. (And I don't even know what the hardware side looks like.) If you've ever tried to independently build an app that uses multi GPU - especially if, god help you, you tried to do it in OpenGL - you may have discovered this insane rabbit hole. There is ONE fast path, and it's the narrowest path of all. Take lessons 2 and 3, and magnify them enormously.
Deep breath.
Ultimately, the new APIs are designed to cure all four of these problems.
* Why are games broken? Because the APIs are complex, and validation varies from decent (D3D 11) to poor (D3D 9) to catastrophic (OpenGL). There are lots of ways to hit slow paths without knowing anything has gone awry, and often the driver writers already know what mistakes you're going to make and are dynamically patching in workarounds for the common cases.
* Maintaining the drivers with the current wide surface area is tricky. Although AMD and NV have the resources to do it, the smaller IHVs (Intel, PowerVR, Qualcomm, etc) simply cannot keep up with the necessary investment. More importantly, explaining to devs the correct way to write their render pipelines has become borderline impossible. There's too many failure cases. it's been understood for quite a few years now that you cannot max out the performance of any given GPU without having someone from NVIDIA or AMD physically grab your game source code, load it on a dev driver, and do a hands-on analysis. These are the vanishingly few people who have actually seen the source to a game, the driver it's running on, and the Windows kernel it's running on, and the full specs for the hardware. Nobody else has that kind of access or engineering ability.
* Threading is just a catastrophe and is being rethought from the ground up. This requires a lot of the abstractions to be stripped away or retooled, because the old ones required too much driver intervention to be properly threadable in the first place.
* Multi-GPU is becoming explicit. For the last ten years, it has been AMD and NV's goal to make multi-GPU setups completely transparent to everybody, and it's become clear that for some subset of developers, this is just making our jobs harder. The driver has to apply imperfect heuristics to guess what the game is doing, and the game in turn has to do peculiar things in order to trigger the right heuristics. Again, for the big games somebody sits down and matches the two manually.
http://forums.overclockers.co.uk/showthread.php?p=27752182#post27752182
And of course actual benchmarks.
http://www.guru3d.com/articles_pages/geforce_gtx_980_sli_review,22.html
And guess what? it's still exactly the same -
So you still lose performance in certain scenarios just as I did in 2012.
£450+ for another GPU only to lose FPS.
Deep breath.
