@ Moogleys your swap GFX cards faster than a Pro's KnickersJOKE lol
which 680 have you gone for ?
Should have stuck with the 670 club.
None youd notice bar in benchmarks, then theres the problem of keeping it cool enough with high clocks.None at allbut it would be shiny
does 4.9 for benching
Pretty good there, what does the memory clock like on it? One of my wf's will do 1320mhz on the core, 7506 on memory. Iirc that was +130 and +700. The second one is an average clocker. +80 on the core +600 on memory on both in sli as thats all the weaker card can do.My 670 is happily running at 1325Mhz on the core at the moment. Not really sure I made the best decision buying a 680.
Oh well.
Damn, ur system sounds messed up showboat. Hope its ok. Boot failure tho sounds harsh, drivers shouldnt cause that as drivers only load and effect the system after post when win loads. Wonder tho, which methods did u do for uninstall and cleaning of drivers, device manager (no) uninstall through programs and features? Driver sweeper after and DDU after that in safe mode?
LMAO!
Hmm moogley what way do you overclock these 670s? I know use afterburner or evga x precision tho i duno if that supports the tripple voltage thing from msi or not. Just thought might give mine a quick go see what it gets to but safely. Dont wana damage it
Last oc i did was on my 460 a few yrs back which got to 800 but used i think 780 for 24.7. So if u can help me oc this thing ill see how i far it can get since it might clock well being that the asci thingy in gpuz said its 92.5%.
I only just updated the drivers from 314.22 to 326.80 with a clean install of drivers with driver sweeper and DDU.+52 on the core and +200 on the mem to get me
core - 1201mhz
mem - 1603
cpu still i5 3570k at 4ghz.
