UPDATE
So here we are, time for an update on my progress.
Exams went well, longest and hardest period of work in my life so far but it can only get better from here and i think i did alright in my exams so it all looks good.
Saw a video on YT which was a tutorial on braiding cables with paracord, and since i owned bitfenix alchemy cables i have always wanted a full set of cables like that so that is exactly what i did.
Started by buying about 400ft of paracord which was only about £20 so great value for money, bought black and white but only really used white in the end.
White Paracord Mess
Then i set about sleeving each and every cable. It took several days in all and my thumb is now utterly ruined after touching molten nylon repeatedly and then pulling out the razer sharp pins and cutting my fingers... Sacfices were made in the learning stages but now i can do it much more proficiently.
Cut Thumb
I must mention at this point that i made a fatal error while doing this. Since all the cables are black, i thought it would be best to only remove a single cable at once, sleeve it, then replace it. But as i got tired one night at about 2am, i pulled out two in a row. I decided that since i could do nothing about it immediately then i would just guess and continue. I tried to get the wiring plans from corsair but they said they couldn't help. I contacted OCUK customer service and, low and behold, Bailey managed to get me exactly what i needed, the wire diagram for the AX850W PSU (which is different to normal as it is 24pin on one end and 18+10pin on the other.) Massive Kudos to OCUK for their efforts here so i thought i would mention that
Thanks again OCUK.
If anyone is wondering quite how you do this, you basically have to remove then pin and slip the paracord over the end like normal braiding but use a still wire to help. Then just melt the paracord at the end over the thin part of the clip so it doesn't slip back over. Then just put it back in. Could do a more detailed tutorial if there is demand but i imagine videos on YT are just as useful.
Melting the End
Part Done
The Final Results
Done Front I/O Connectors too
As well as braiding a metric tonne of cables, in 2 days i have painted a couple of screw ends so they dont show up like beacons on the rad fans. Very simply just painted, im sure they might chip a little when i put them in but its better than them being bright shining silver like before.
Up next will be blocking up my GPU and then fitting and testing. Exciting times for me!
