This guy is made of win... yeah, it definately got some attention at i34, cheers for taking time out to come and have a look at it dude!
Here's a quick show off shot... this is taken with NO extra exposure time (or whatever the technical camera term is called...) straigt up how it looks:
Thanks to bit-tech for showcasing it in their i34 roundup =D
mine will be better
you got any side panel cuts vipe?
viper, is that uv tubing or liquid?
 (roughly translated as, both)I would have responded with to following answer:I want to watercool mine, however I don't really know the first thing about watercooling.
Bad idea?
Id recommend doing something bigger first. Its extremely frustrating at times building in something this small.
I have signatures turned off![]()
That lookc amazing, im not suprised you have that pic in your sig![]()
looks cool matey. i need some UV goodness. this ** main rig now?
How long is you radiator?
I remember checking this case and looked like there is no way to fit normal 2x120 rad in it... I think normally its about 288mm and case was shorter than this..
Awesome stuff, well done![]()
