Patch panel tidiness has a halflife, you should take another photo in 4 weeks time, another in a few months...
Good work - guessing your on a placement year?
Red = Servers?
Yellow = Data/PCs
Blue = VoIP?
Grey = Printer?
That patch panel looks familiar
Good job on it, looks a hell of a lot better than it did at the beginning of the week! Next up is the server cab *shudder*
I hear you there mateyIt's all CAT6 too which was a PITA because its not as flexible as CAT5.
Some numpty thought it would be a good idea to feed each cable through the holes to the back, down the back of the rac, then out the hole at the bottom to the switch - making tracing cables nearly impossible...
Invest in some Neat Patches, they're well worth the cash
