Looking at similar build myself but i was gonna put fans underneath sucking cold air in, newbie to watercooling and probably nothhing in it, i dont know.
Can you measure the distance in mm between top rad and the metal plate in the drive bay and to the top of the motherboard, i wanna know if a 80mm will fit, this would be of great help to me, thx.
Hi mate, not got a tape measure in me at the mo. but here is a pic of my 60mm, there's probs about 15mm to the top of my MBand about 30mm clearance to the bottom of the optical bay.
If you bear with me I'll get a tape measure tomorrow hopefully
. I've just ordered some mayhems red dye of eBay and picked a bottle of de-ionised water up from asda. Need some silver coil now I think. Will order some from overclockers on Monday.
