Thought I'd post an update seen as the system has been up 2 weeks or so now and the system is fully bled etc! Probably gonna change the position of the res to above the 2 gpus at the side of the case as that will remove the 1 and only kink I have in my tubing, although I still need to make sure it'll actually fit their first lol.
Should have ordered my dust filters far sooner also as I've just fitted some black metal antec ones to the top rad to stop dust from settling inside the case when the power is off, which is sadly what has happened! Gonna have to get some compressed air and give it a good clean already, which is annoying.
Anyway some new pictures using the girlfriends digital camera.
Corsair 800D 240mm rad mod by
jjohnson2012, on Flickr
Modded bay for where the 240mm radiator sits. Mike Gunz did most of the mod as I bought the case from him, although I made it dust proof and added some screw holes to secure the rad to the case to avoid vibration and make the case easier to move if necessary.
P1070536 by
Side off with some cables showing still due to having to route a molex from my PSU to my motherboard due to an SLI power problem! Still haven't got round to making it a neater fit yet.
P1070535 by
Case side on and the camera doesn't really do it any justice.
P1070541 by
The custom made GPU blocks from EK which was arranged by RKJoneil + backplates. The performance on them is superb and even though cleeecooo will hate me for it, nickel black acetal was still a good choice
Look at the dust though already!
P1070543 by
The OcUK assembled D5 vario pump + D5 HF top!
P1070542 by
The EK LTX waterblock
P1070529 by
New mouse and keyboard + gaming monitor to go with the system. Corsair K90 mechanical (red switches), logitech G9X mouse and a BenQ XL2420T 120hz monitor.
And finally:
heaven benchmark 2968 by
OcUK's highest 580GTX SLI heaven score
