I've been away all week, back now though. Have some bits to do on the house tomorrow morning, then hopefully the afternoon will be spent on the golf.
Plans for the engine bay have now changed! Guy from work has offered to spray it the same colour as the rest of it in 2 pack paint so no hammerite under the bonnet
Going to dismantle the passat hubs tomorrow and hopefully get them shotblasted, also need to take the dash out and remove all that horrible seam sealer so we can stich weld the seams.
Picked up lots of parts this week:
From VW
Full set of wheel bearings
Various under bonnet brackets
New indicator lenses
Bolts and lock plates for the bottom ball joints
From the painters
1l of Red top coat
1l of primer
1l of Activator
1 tin of brush on seam sealer
Lots of wet and dry
Also been in contact with the guy that did the full respray, he has pictures of the work he did and is going to email them to me. Also got the colour from him..... It's radiant red from a..... Ford
Don't tell anyone please
Time wise my aim is to be at the Nurburgring on May the 15th with the golf!
Will update with some pictures tomorrow
