Raikiri said:And it is about the biggest case available bar a tower! I say he cheated... try it in a Super Lanboy![]()
send me one, ill do it easily
welshtom said:yea, easily. if you think logically it will easily fit in.
My good mate Matt100 had dual loops in a pc60. much harder than a single in a lanboy.
My new shuttle is about to be watercooled too![]()
Nix said:I'm thinking of getting a Hyper PSU and some new, less messy IDE cables.
Think that will do the trick?
Yewen said:Or the odd Yewen have one terribly unstable and its replacement sounding like a jet, then later blowing up killing the system.
Tagan and Seasonic all the way personally, burned 2x out of 2 PSU's from Hiper.
KizZ said:That PC-7 looks nice and roomy, you should make it tidy a bit more which should improve the airflow a bit. Wow theres a lot of space between the drive and the PSU. Theres only like 2 inches or maybe less space between my Hiper and DVD drive in my Lanboy. Roflmofl![]()
My biggest concern on yours now is the floppy cable reducing airflow. Persoanlly I'd do without but if you insist on a floppy then try to route it under the floppy bay and down the back of the HDD cage. Easilly doable if the cables long enough. Other than that looking a lot betterNix said:Yeah, fair bit of room, it's just akward because I've got an 80mm amber running just above it and I don't want to get the wires caught in the blades.
I'm going to get some round IDEs and cable wraps soon anyway and a modular PSU, so that should make things easier to tidy.
BigDom said:And just to prove you can quite easily keep a PC7 tidyish
Put the CD-Rom in the lower bay to help with hiding extra cables.
No need to worry about the upper blow hole, totally unneeded for most builds.
It's quite a long case front to back so really cable management isn't hard at all.
hehe thankyou and yeah it is a little dusty.. should have seen it when I took it out of the old PC. Least now it shouldn't get worsepabloB said:Good cable management - shocking amount of dust though! lol!
There's 9 HDD spaces, although 1 will be taken by a DVD and another possibly by a Floppy.Talbs13 said:Is there only 3 Hard Drive spaces? Isnt that a bit poo?
