My Lian-Li Arrived! (Pic Warning)
  • Thread starter Thread starter Nix
  • Start date Start date
Talbs13 said:
Is there only 3 Hard Drive spaces? Isnt that a bit poo?
(It can hold 5 out of the box, then for £15 you can add 3 more and still have your DVD drive by use of a Lian Li EX34 ( http://www.lian-li.com/Product/Accessories/HDD_Kits.htm )
When do you need more than 3 in your main rig is the main question, 2 raptors raided and a storage drive are all you normally need, so really Lian Li give you what you need and do not increase the price of the PC7+ by £20 to give you more hard drive space which 95% of people will never even want.
I have a Cheiftec dragon full of hard drives, but my V1000+ has a raptor and a 250gb Caviar, that is nowhere near its capacity and I will never need the second hard drive cage, so if the case was £10 cheaper without it I would have still purchased it.
welshtom said:
yea, easily. if you think logically it will easily fit in.
My good mate Matt100 had dual loops in a pc60. much harder than a single in a lanboy.
My new shuttle is about to be watercooled too :p
Ta daaaaaaa
and tidy.. its not hard
well actually no it is hard but its not impossible.
2 loops, 120.2, 120.1, 3 hard drives, 2 7800s, 2 5.25 bayres and a silicone partridge in the overclocked pear tree.
Raikiri said:
Tut not much room
*posts pic of smaller case with better cable management*
Keep in mind theres 4 case fans and a CCFL in there too :p
Although it doesnt matter too much with the PC7, no window.
Rakiri what case is that :eek: I want that case! :p its a lanboy isnt it
