Okay, started with the whole battery in the boot business.
Firstly, here is the standard 205 GTi engine bay:
What I want is to move the battery into the boot to free up some space and help a touch with the weight distribution.
With the battery gone, you can move the airflow meter and fit an induction kit where it won't just suck warm air from the manifold (which is at the back on 205's)
So first things first - get rid of the piping and airbox.
Nice pile of useless bits:
After this was sorted, I removed the battery, then the airflow meter (which will later be repositioned. I also removed all the now pointless bracketry for the meter, it all helps neaten things up.
205 GTi's have two main live points to the battery - fuel pump relay and starter. As on nearly every one I've seen, the fuel pump relay terminal was knackered and fell off in my hand. So, new terminal, new wire (the thick red cable on the left)
I've had a relay connector fail during a rally once and it's not even remotely funny. I then got out the cable ties and sticky pads and ran the cable up the inner wing. Alongside it, I ran a second cable which will be connected to the starter itself
You can see the old battery tray here on the left which has a coating of rust. I'll grind that off with a flapwheel and give it a dose of red hammerite to protect it.
So, here's the bay as it stands - no battery, and for now no airflow meter (need to do some jiggery pokery with the old induction pipes to get it back on)
I was about to connect it all up to the starter (hence the wire draped over the engine) when it started to **** it down with rain, so that's it for now....
