mk1_salami
mk1_salami
Really inspiring project Lopéz - I'll look forward to the next update
Probably, most seats can be adapted for other cars. These ones have flat base so shouldn't be tricky to mount up to the mounts of another car, or a universal subframe.saitrix said:Starting to take shape, really does look good.Now this may seem a stupid question but would those seats fit other cars, your old ones that is.
Mike306dt said:It amazes me, just how much you know, have you just learned as you go?
I've already got a lot of the parts I need - seats, harnesses, roll cage, fire extinguishers. I do need to build or buy a sump guard and a tank guard at some point. I also have uprated suspension and brakes, as well as a choice of OMP or Magnex exhausts to bolt on at a later stage.wild58 said:very intresting thread. apart from an induction kit and ripping out all the non essential bits are you guna be buying anything else for the car?
That's pretty much it.Berger said:Figured i might as well ask here since you have one installed
Engine bay braces; i dont see why they are needed/how much difference they will make, i guess it reduces chassis flex, therefore reducing mid corner grip, but increases steering response. But how noticable is this/are there any other reasons for using one?
