Hello all,
I hope this is the right forum to post in, it looks like there are similar threads here.
I've got myself in to a bit of a pickle with my data storage over the years. All my main storage is in my main PC which is not ideal. I used to run 2x 1.5TB RAID 1 and 2x 2TB RAID 1 but I disbanded the arrays a few years ago as I ran out of space and now run all in JBOD. My drives are very old (2009) but going strong (WD green drives).
I've been thinking about getting a NAS for some time now but I am not sure what the best options would be. The simplest and maybe cheapest I think would be to buy a synology 220+ with 2x 10TB WD red drives and run them in RAID 1. I did think about running RAID 5 on the 420+ to gain some extra space but the cost of adding 2 more drives will be quite a lot.
In addition, I would like to install 2 security camera's at my house. 1 for the rear, 1 for the front. I will be running network cables to the 2x outside locations so I would like POE camera's. I currently have a netgear GS308P (55w) POE switch with only 1x nanoHD AP connected to it (no plans to install any more).
My questions:
Does a synology NAS sound like it will suit my needs? Should I look at creating a self build instead?
What camera's should I get?
My questions:
I might just have to bite the bullet and buy at least 2 new drives and use SHR as you suggest.
