Thanks for the detailed reply. I was looking to do the same with regards to only starting with 3 hard drives (WD red 4TB drives look best bang for buck at the moment). I am not sure I can be bothered to go down the shucking route and hope I get lucky with a good drive. The reason I was interested in the 1520+ over the 920+ was so I could swap to SHR2 in the future when I start putting bigger drives in the system without losing so much available storage.
Hmm, I no longer have a UPS so that'll be another cost if I go down that route. Maybe I could add the NVME drives at a later date once funds allow for a UPS. I will be using the system for surveillance too so I am not sure if having the SSD for write cache would be a good thing in that respect.
With regards to the 1Gb ethernet issue, that did put me off until I watched a linus video where he uses link aggregation to increase to 4Gb ethernet. I would need a switch that could support this though so again, another cost if the 1Gb ethernet becomes a problem for me in the future.
