I think I’d pull the box in at least 1cm from the edge because the system won’t be able to see anything crossing the line if the line is right in the edge of the image. Remember it’s looking at the picture and saying ‘there’s a person, and they’ve crossed that line’. If you don’t have the cross option available then you’re relying on Appear and Appear is a weaker rule than Cross.
And LDC is a bit marmite. Lens curvature REALLY annoys some people. Did you get the 3.6mm or the 2.8mm?
And yes, definitely untick Smart Motion Detection.
And yes, that looks fine for the schedule.
And the two schedules are (top option) when the IVS rule is running and (bottom option) when you want the siren and/or flashing lights active.
