This was mentioned in other thread on this forum but I think that it deserves to be here, definitely.
It seems that sometimes potential users of this monitor are worried about the movie playback and "twinkling effect" especially after the BeHardware review (only) where there was just one particular category where the monitor didn't shine - movie playback. In reality, is that really so ? I would like to share a few words here.
Movie playback noise (or twinkling) exist on all LCD panels. Usually, such noise is dependant on the panel type and most importantly panel overdrive control. If you want noise friendly panel, probably the very slow MVA panels (at least 20ms) are preferable and they will do the job. Unfortunately you will have two side effects: strong afterglow & ghosting as those panels are simply not fast enough for fast action movie sequences. When you watch such sequences, blurring is visible, ghosting is persistent and it's usually presented as coloured trail of light. Simply put, it's not acceptable and effect is similar when you are playing the fast action games on LCD panel with very slow response time. This the major reason why I think that for the movie playback it's essential that panel is *fast*. As the unfortunate downside, overdrive kicks in with the faster panels and you are greeted with the movie playback noise. Maybe "something in between" and possible compromise are the faster 8ms MVA panels where the movie playback noise is less pronounceable (but it's still there). Now, with the MVA panels viewing angles are so so (and this is important for the movie playback) and picture quality/clarity and colour richness are simply not on the same level as with the new generations of the IPS panels. Also, IPS panels may offer better viewing angles. It seems that with the new generation of the IPS panels (AS-IPS) some progress was made for the movie playback, but of course it's still again far from perfect (as for the most LCD panels around). One interesting thing about the LG.Philips 1600:1 AS-IPS panels is that they are supporting the 1600:1 contrast ratio with the Advanced DVM and when you combine this mode with the custom monitor profiles and brightness it's quite possible that you may minimise the twinkling effect and results are really surprising (as far as I can tell). Also, NEC monitor (and US version of course) are declared for the movie playback, so generally movie playback should be on the acceptable level.
Now, you probably wonder where this is all going and if there is any logic in this ? Unfortunately, there is *no* perfect monitor panel for the movie playback. Simply as that. If you want dedicated movie machine with the excellent reproduction quality ... LCD TVs are probably preferable option for now.
Solution for the LCD monitors and movie playback is that you simply watch your movies from the distance. Even from 1.5m movie noise or twinkling is starting to fade away and it will be less pronounced and at the same time movie playback will be more enjoyable. At the end did you ever tried to watch your LCD TV from the close (like 1.5m) proximity ? I tried with my 32" Sony LCD TV. It's quite horrible (even with the digital TV channels) as the picture noise is present & persistent.
For the people who are concerned about the movie playback, maybe some of our dear forum readers, who are already using the NEC monitor, can help here and post their impressions about the movie playback. It would be probably more useful than my chit-chat from the above As I already mentioned to you, movie playback was acceptable for me (especially after some monitor tweaking) but in order to have global picture maybe some other users comments are more then welcomed.
