Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
when you say resolutuon expansion....you mean it fills the screen?
Raymond Lin said:when you say resolutuon expansion....you mean it fills the screen?
Raymond Lin said:What Richdog ask for is that he doesn't want it to fill the screen, because that stretches things.
Raymond Lin said:What does off do ?
When select say 1280x1024, do you get a tiny black bars at the top as well ?
The answer i am looking for is yes.
Raymond Lin said:shame this came out 3 weeks after i got my Phlips and £70 more...can't really afford that.
Raymond Lin said:technically its call scaling, thats what its usually refer as. Would be good if you use that term instead of NEC's own term to reduce confusion
igors said:OK ... think I got it !
- Full is stretching the image completely, so that whole screen is covered.
- Aspect is trying to simulate the monitor wide-screen aspect rate 16:10 on the selected resolution. It's stretched little bit, but there are still black bars left/right but not at the top (as far as I can see).
- Off is disabling any picture scaling processing. Resolution is natural as it should be. It's sharp and unaltered in any way. And, yes, there are tiny black bars on top/bottom and larger ones on left/right.
Hope this helps.
Raymond Lin said:That's cool, Richdog....I think you found your monitor !!!
igors said:New review update 18/02/06 is available ! Enjoy.
I have few questions for the forum administrator:
- Can you, please please please, update the main thread subject to
include the "18/02/06" date. Not sure why I can't do this. Last time, it
was auto magically updated ... probably touched by magic hands
of the forum admin.(
Baddass said:done for you. It was me who did it last time too as i'd read through and realised there was an update. Only just managed to read through this thread again.
