finite said:Yes, BeHardware (sister site ?) often use the phase twinkling for video, but fourmillement translates to swarming, perhaps more accurate as it doesn't infer brightness.
Nutster said:... my room is dark most of the time, so I wont get reflections![]()
Moderate ambient light or just desk lamp (behind the monitor) is doing the job just fine.
Actually, I had that feeling that review was concluded yesterday. Somehow it's always rising from the ashes again and again and again, like Phoenix
MrLOL said:question is though
is it (the NEC) worth the extra £80 over the philips ?
Depends whether you're a gamer or not I suppose, and also whether you want CRT-like black levels or not.
(In other words yes).
Sometimes, it's not essential that you consider only the panel "type", when short-listing any desired monitor on your shopping list. Of course, it's important bit, but it may happen that electronic control unit or the overdrive control of the panel itself may improve things quite interestingly (like the new LG.Philips 1600:1 technology, for example).MrLOL said:cos we reckon the philips probably uses the same LG Philips IPS panel as in the NEC dont we ?
