oh it could be the mobo screws, nice one stulid. i will check now.
lol bulldog i got the OEM version so no stock cooler![]()
the fan wire will not reach, i can't put it into the cpu fan 1 slot...
some people are saying that the cooler sound disappeared for them after 2 days or so, so i think i will wait.
i ran prime95 for 1 hour and max temp using CoreTemp on an individual core was 52C and this is at Stock. I am not sure if that temp is good or bad... what do you guys think? bear in mind this is just at stock..
what temps do you guys reckon i should expect if i OC to 4.4? and do u recommend or OC'ing or shall i stay at stock?
ah cool thanks, these new SB cpus go up and down in speed when required. when i overclock will it stay constant 4.4ghz? is there a way to turn that system off? and do recommend turning it off?
thanks
Just need to sort out why the HD activity light is not workin and then i should be done!
