Ok ta for that . Never used the option and had tried a few things and could not replicate it .
The thing that annoys me most is you set the car up in simple mode ... Then go to advanced and the settings change and then go back to simple and the go back to default . So you cant set basic settings and just go to advanced and adjust ride height and tyre pressure .
Persil
The thing with settings is you have to go out to menu then back in again for the game to update.
My process;
1. Enter tuning, switch to simple mode (if needed) and change/ adjust settings.
2. Exit to menu & save profile
3. Go back to tuning switch to advanced mode and make changes.
4. Exit to menu & save profile.
It's important to do step 4 to update the game. I've found if you
don't save your profile, when you start a race your settings are OK but if restart from the pause menu (after a crash, not happy with launch etc) your tuning settings revert to the previous save. This seems to happen to me anyway.
My 'Springs and Dampers' settings;
First 6 set to soft or short, fully left
Last 2 set to soft, fully left
One's in between kept at default.
Right I need help please. I've recorded a video using fraps. Now I've never uploaded a video to YouTube but I do know there's a 2gig limit. Can anyone recommend a convert tool to reduce the size (it's currently 3gig) but keep most of the quality that's compatible with YouTube? My uploads only 768k.
Thanks
