That's just unbelievable Wedge - great time, and I suspect the winning time this week. Any chance you could post the rest of your settings?
Hey Dan, i seem to have found another car/track combo like the Elise a couple of rounds ago, where i just seem to excel. Honestly i can go round lap after lap in the high 51's, low 52's.
As far as tuning goes, im very gentle, as you have said ive posted my main settings, the only other settings i change are the 'Springs & Dampers' I have moved every setting one notch from its default towards stiff. (but will post screenys later)
I personally think its down to driving though (works cars are pretty good at stock), finding the lines and feathering the throttle is really key to keeping momentum.
1st corner, flat out
2nd corner, down to 4th gear, whilst sharp dab on brakes, then turn in hard, get back on the gas, feather the steering out and get striaght asap.
3rd corner (jump) LINE is key here, watch my vid.
4th corner, DONT brake to late, to early is better, all the grip is on the inside/middle of corner.
5th/6th, flat out depending on line (sometimes need to lift slightly whilst entering)
7th corner, drop to 3rd gear, whilst sharp dab on brakes, (again DONT brake to late, to early is better) turn in get back on the gas asap, 4th gear comes quick here (if you use my gearing) so be ready to change up mid corner.
Hope that helps
