This is so hard. Dunno if I'll get better than this, though my driving is slowly starting to improve.
<snip>
That's the main thing Merlin, even small improvements are going in the right direction, indicating you're driving, knowledge of the track is getting better.
This is/was an issue prepatch.Very true indeed.
What do you make of this nikaz. The game doesn't save values where the slider is pushed fully to the right. It takes them down one notch to the left. Weird, this only happens to the fully right settings. These are the ones fully to the right:
Springs and Dampers
Front & Rear Damper Slow Bump 6,300 (reverts to 6000)
Front & Rear Damper Fast Bump 3,700 (reverts to 3500)
Front & Rear Damper Slow Rebound 10,800 & 12,800 (reverts to 10,500 & 12,500)
Front & Rear Damper Fast Rebound 7,800 & 8,800 (reverts to 7,500 & 8,500)
Differential
Limited Slip Acceleration Lock reverts from 100 to 95
Limited Slip Preload reverts from 110 to 100
Gearing
1st Gear Ratio reverts from 2.83 to 2.88
2nd Gear Ratio from 1.92 to 1.96
Aerodynamics
Front & Rear Downforce revert from 18 to 17.
I'm fully patched with 1.02.
Right click the 'Shift.exe' select properties and see what file version is stated. It should be 1.02. Anything else (1.00 or 1.01) means the patch wasn't fully installed correctly.
It's Thursday evening with a couple of days of Season 2 Week 8 to run.
I'm posting earlier than usual to give those who may be working Saturday, ample opportunity to make a nomination.
At the time of posting the current standings dictate that;
01. utajoker
02. grs_link
03. Nem
get to submit nominations (Car & Track) for Week 9.
You may submit you're nominations via email to:
[email protected]
or if you prefer, you may post your nominations between 5pm & 6pm in this very thread Saturday afternoon.
hows it worked out that im submiting a track/car i was 6th or 7th fastest.
email sent.
Hey guys.
Recently got Windows 7 and have not had the pateince to go through the game again to get enough money or cars to carry on with this championship.
Lazy I know!
But can I get my save game from my XP (32bit) and transfer it to my Win 7 (64bit) HDD?
Also with the 'Persona' ingame, will it keep my cars and credits if I log onto a different machine?
Thanks in advance guys and hope to be racing again!
Brackish, there is a save file in the OP that you can rename to whatever you like. Instructions on its install in the first post.
Good stuff Merlin. Over 2 seconds improvement on your last posted time.Wow, I'm getting there. I'm not last anymoreQuestion is, can I make it to the top ten.
<snip>
Is it the track knowledge improving your time or more getting to grips with the car?
Still, good time danswan.Very little time with this weeks combo - shame as I know I could get a bit quicker and it's a really challenging one - my best time:
<snip>
