Need help please
7 Feb 2011
London
My mates old Radeon 5770 has broke, he has a dell pc with a 350watt power supply which only has 1 six pin PCI-E cable he has a budget of £150 and needs a new graphics card to go in it, any recommendations please?
Thanks guys
What is the rest of the machine? To be honest, a 350W is not going to power all that much especially if it's one of those nasty PSU's but he may be OK depending.
to be honest, to come in under £150 a replacement 5770 is probably his best bet
all the 6xxx cards that are faster than it would also need a new PSU so it's tough to come in under £150 for both
if his CPU is also of an older type there's not much point spending a load of money on a new graphics card and PSU when the CPU will be holding him back
Might be OK if that PSU can actually supply 350W. Touch and go though. A HD 6850 would be a slight upgrade or a side-grade. To be fair though, if that CPU was overclocked a little and installed with a better PSU the upgradeability of it is increased a lot.
Depends whether the motherboard has the Dell specific connectors on it or it is generic ATX PSU connections?
Personally I think you're better off getting a better psu as it may lead to problems later if you get a new gpu. Maybe even just spend £30 on a second hand one. Then you could over clock your CPU and gpu and not have to worry :)
Gonna need a new PSU to run anything worth having 500W is the recommended for most. If he can stretch to it i would have the 6870.
YOUR BASKET
1 x MSI HD 6870 OC 1024MB GDDR5 PCI-Express Graphics Card £119.99
1 x OcUK Swift 750W V2 Silent Power Supply £35.99
Total : £167.38 (includes shipping : £9.50).
OR
YOUR BASKET
1 x OcUK GeForce GTX 550Ti 1024MB GDDR5 PCI-Express Graphics Card £91.99
Total : £138.48 (includes shipping : £8.75).
Poor call on those PSUs :eek:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-059-CS&groupid=701&catid=123&subcat=
Um yes it does.
500 Watt or greater power supply with two 75W 6-pin PCI Express® power connectors recommended (600 Watt and four 6-pin connectors for AMD CrossFireX™ technology in dual mode)
http://www.amd.com/us/products/desk...6870/pages/amd-radeon-hd-6870-overview.aspx#3
Interesting how you also need a 500 watt or greater power supply for a 7970 as well!
http://www.amd.com/uk/products/desktop/graphics/7000/7970/Pages/radeon-7970.aspx#2
OP: the 430W PSU will do fine.
Um yes it does.
+1.
@Gav_88 I suggest you take a reading from the wall from a system with a 6870 in before posting such nonsense.
So, no it doesn't.
