I sorted mine...
You have to remove the old drivers before installing the latest 5.0's as some weird message pops up with something about Binary files missing :S
I had no clue what that was.
Follow the instructions on the driver download page and it should be fine.
Although sometimes when i start my pc it says device malfunctioned and is not recognized and sometimes it works but it won't connect.
I just turn my pc off for 2 mins and then back on and it's fine..
Netgear seriously need to work on there drivers for version 6.0..
Still not quite happy.
I ended up uninstalling and reinstalling these drivers about 9 times now.
My wireless connection says...
Wireless Connection 10.. lol
Also for some reason it's changed from my auto channel to one that i don't usually use.. but as long as it's working its ok
Don't know if i made sense there.. wasn't really concentrating..
Ok it just crashed again from the time it took me to start my pc to writing this message and clicking submit.. it's just crashed... For about the 15th time since i've had it.. probably more..
Edit : Whilst typing this message the adapter stopped working for 45 mins.. After turning my pc off about 6 or 7 times it started working again out of nowhere for no reason.. no settings changed.. no nothing.. it just started working...
Can i ask where you all have your adapters placed? I've moved mine to a usb port in the front as at the back it was under my whole desk.. now it's sort of half and half..
I'm thinking of ordering a usb extension cable as the one with it is like 0.4m haha..
I just moved it out from the desk and it got 2 more signal blobs and went to 108mbps..
It should be running at 270mbps.. I wonder if it'll go up if i extend it to the top of the cuboard down here..
Perhaps i'd need to buy 2.. i'm not sure 1.8m would work..
Man this adapter is causing mayhem..
I don't want to wait for them to be delivered again in 6 working days like last time..
Hmm..........
Most of this is probably jibberish.. sorry. Wasn't really paying attention..
I was just typing every single thought that came into my head.
Ok i'm still doing it. *hides*
