Try swoping the cables to the speaker around on the motherboard, you could have the polarity wrong.
You should have a jumper on the motherboard to reset the BIOS.
like i said it could be your power supply...You can get the power supply to 'spin up'...but it can still be faulty.
It could also be your graphics card as well, or your cpu =/...but hopefully it isnt that severe obviously.
Do the fans stay at a constant RPM as well?
just spin up to top rpm and then it just cuts off, i think i'll have to leave it for tonight and start testing stuff in my computer![]()
does the same thing happen where the fans spin up and then it just turns offCould be psu then, had that at work numerous of times.
ok just home there, i'm going to take it all apart and build it on my table....if it doesn't work i'll try my psu (in sig) and see if that's the problem
EDIT:
Yeah it has showed those symptoms before, but we've also had them where thing's have been shorting for some reason...Could be something as simple as a faulty cable somewhere.
