worked fine for me when i wasn't using stylish.That doesn't work, they come back.
and it still works, just disabled and blocked.
forums.overclockers.co.uk##.fa.fa-facebook-square
andIt worked! Thank you
You just delete the post and wait for the little 'draft saved' popup in the bottom right corner of the edit box to appear - it's gone then. I've set it to save a bit more frequently to help.
tom_e said:If you hit the "Save" floppy disk icon it also gives you a dropdown with options to "Save draft" or "Delete draft"
and
forums.overclockers.co.uk##.sharePage
for the twitter/fb etc at the bottom.
no idea, but if you didnt know, you can click the floppy disk and delete draft.When you type a post in the quick reply box now it saves the entry before submission, e.g. if you navigate away from the page it's there when you reload it.
Question, can mods see this cached data, or is it done clientside?
[like]no idea, but if you didnt know, you can click the floppy disk and delete draft.
Can we please also make the rest collapsable, ie:Also now that collapsable forums are working is there any way we can sort them i.e the ones I've collapsed I'd like to move to the bottom of my list as they are no use to me.
It's the proper division of the posts that really does it, bring it to the default theme please!
