Please show me where I get one of these![]()
Interestingly the two vocal ones around your post are both still textbook engineers so real world application is yet to strike them down.![]()
[TW]Fox;18301478 said:Why would you want big power?
Is it not better to design cars that suit the market they are aimed?
Bear in mind this is the good old VAG 1.8T we're talking about here afaik, if you're that desperate for more power, a 190-210bhp remap (depending which 1.8T they put in it) is only a couple of hundred quid away anyway.
Why would a market suddenly vanish if you can deliver more power for the same cost by having a well designed engine?
It's all about sizing the turbo correctly (which means getting good quality data about the actual turbo), getting a good quality turbo, and designing the engine and heads well.
Because market segmentation has little to do with engineering and is something that marketing people invent.
If you can design a good package that does things correctly, why create a sub-par version of it that does not do things as well?
If you only want 160hp and torque from a turbo petrol engine, why design a 1.8L when you can achieve the same figures from a smaller, lighter, 1.2 or 1L?
Or you could have designed that engine to begin with to be a market leader as far as power etc goes
It's the TSI engine.
A showroom.
I'm an Electronic Engineer with a mere 2 years real world experience, I picked up a textbook knowledge of motors while I was studying Electronics. So unless I move into the automotive industry It'll stay fairly textbook. Isn't Fox a textbook accountant?
Carry over components - get ready for it![]()
Oh ok then, I wonder what the remap potential is on that compared to the old 1.8Ts?
Which turbo is this that holds boost for such a wide rev range with +75 adiabatic efficiency yet holds turbine inlet pressures below 2 times MAP?
Wiki suggests it's K03 equipped, so it'd probably be good for 190 if you wanted to push it. I somewhat suspect this would be a rare occurence in a Yeti though![]()
lol
Aircleaner, intercooler. mate I could go on all day.... its kinda my job.
