Its quite a naff design, the more i think about it the less happy i am. I know it's quite cheap and all, and for the price (and now it's seated correctly) i don't think you can argue with the cooling.
It's really tricky on my board to push the feet in. All around the CPU are copper heat syncs, and the 4 feet on the bottom of the ninja are basically under the edge of the heatpipe. You don't stand a chance trying to fit this with the board inside the case (not that i tried). Also, because of the tightness getting the board and ninja back in to the case i had to take the optional fan off the top. So when the board and pipe were back in the case and screwed down, putting the fan on top then and trying to fix it with the mounting bracket put pressure on the pipe and loosened the feet again.
Id recommend people try and get the first version looking at peoples comments, even if its just for the miracle bracket to hold it down.
