not happy with ssd speeds, thing something wrong
PAD
PAD
19 Sep 2011
Hi, i just brought my 1st ssd, ocz agility3 240gig, first loadup seemed fast, now its slow as hell in my view, not what i was expecting.
this is a screen shot of my speeds, it means nothing to me but when i look at it, it seems horrible.
now under the pcidde - BAD it says intel(r) 6 series/c200 series chipset family 4 port serial ata storage controller - 1c00 bad
also looked at Sean's Windows 7 Install & Optimization Guide for SSDs & HDDs but still no joy, one thing it says to turn on ahci sata in uefi but it just crashs my computer on each load so meh
help plz
added note , not sure why image not showing up but when i rightlclick and copy the link to ie9 it works, so meh*/**fixed
set to ahci in bios,your only in ide mode,what motherboard is it?
click this reg file,run it,then restart pc into bios and set sata ports to ahci,save exit reboot into windows job done
http://cdn.ithinkdiff.com/wp-content/uploads/2009/05/ahci.reg
thats my problem if i set ahci in my bios it keeps crashing and doesnt even load windows up
my mb is Gigabyte z68ap-d3 intel z68 board.....
because of that regfile u linekd, it works 100% now, i love u, let me test it
its better now, so does that now look fine? i thougt with ssd's tho windows would load up in like 20 secs or something, mine doesnt seem to do that but o well
It depends,gigabyte boards have longer BIOS page laoding times,once past that it should be quick,everything looks ok for sata2 speeds,it bsod before because you didn't set ahci before you installed win7,but that reg file does it for you without reinstalling
Makesure you put ssd onto Intel SATA 3 port not SATA 2
Install Intel RST.
Version 10.8.0.1003 here (the 6.89MB file)
Version: 11.2.0.1006 here (the 12.35MB file)
The newer version 11 is designed specifically for Intel motherboards.
It may install on non-Intel boards or it may not.
This should have you using the Intel AHCI driver instead of the generic Microsoft one.
It may improve things further.
This post is helping me slightly , i have a crucial 128 SSD M4 , Ive only just noticed it was set to IDE , so i changed it to AHCI , But when i re-booted it halted on an error which was MBR error1 , please insert floppy???? , I gave no thought to how i installed my hard drives and connected them up to any sata port?? Do they have to be in specific ports , i also have a 2tb baracuda and a 3tb baracuda. Any Ideas?
My rig
Corsair Obsidian 800D Case
XFX Radeon 7970x2 Xfire
i5 2500K O/C 4.5ghz
16gb Kingston RAM
GA Z68x UD3H-B3 Mobo
Xonar DGX 5.1 PCI-E Soundcard
Corsair SP2500 2.1 Speakers
Corsair Hydro H100 Cooler
120GB Crucial SSD
Seagate Baracuda 2TB HDD
Seagate Baracuda 3TB HDD
Dell Ultrasharp U2711
XFX 850W PSU
Corsair 1300 Headphones
Razor Death adder 3500dpi 3.5sg Mouse
RazorBlackwidow Mechanical Keyboard
Microsoft HD LifeCam
if its gigabyte i think its what surveyor says the white intel sata3 ports,connect ssd and sata3 hdd to those,and use blue intel sata2 for the rest,did you click and run the reg file and follow the guide i posted above to enable ahci after windows installation?
and do what surveyor says and install the intel rapid storage drivers as it will help improve read/write figures
heres what i get with crucial m4 on intel sata3 port/ahci mode
