The only similarity between Notepad and Notepad++ is that they open text files. Other than that they're effectively totally different things. Notepad++ has syntax highlighting, CR/LF viewing, text comparison, tabbed viewing, macros, plugins, checksum generation and many other things.I don't really know what Notepad++ brings over Notepad but there are many text wrangling programs for the Mac. I use TextMate (it's free), BBEdit is another popular one (which isn't free if you want full functionality) and I'm sure there are loads of others.
Same here and as it's supported on Windows/Linux too I can hop between environments more seamlessly.I use Visual Studio Code, as do most developers I work with who use macOS.
Looks like this is the way to goI use Visual Studio Code, as do most developers I work with who use macOS.
While I love VS Code when I am coding, I find that for the reasons I used notepad++; it's too much as by the time I've opened VS Code and all my 70 million plugins have loaded, I could have already finished what I would have done on Notepad++.I use Visual Studio Code, as do most developers I work with who use macOS.
I'll give it a look-see.I think that’s the sort of thing TextMate does as well.
TextMate: Text editor for macOS
macromates.com
The main uses I had for Notepad++ were either:Another vote for vscode here
Are there any specific notepad++ features you need?
oh I love sublime <3yeah i guess vscode prob is good for that but isn't as lightweight.. I don't really notice it starting up mind.
I've used textmate also in the past and its a capable text editor.
a colleague of mine swears by sublime text too if you haven't tried it.
Random first post and nice bump .Finding a Notepad++ replacement for Mac can be a bit tricky, especially if you're used to its functionality. Have you checked out Visual Studio Code?
