https://www.techpowerup.com/reviews/NVIDIA/GeForce_RTX_2060_Founders_Edition/33.html
The 2060 is the same speed as the V64 but comes with Ray tracing and DLSS, as will as being a newer architecture that will liekly scale better to future games and has more room for future drive optimizations. The 2070 also many newer features that can give performance boosts in games.
I don;t think the vram is really much of an issue. It wont ahve the power to do 4K with all the eye candy in future games , settings will need to be lowered.
Golden review 2060 sample vs reference vega cards. Frametimes/min fps are also more important, the 2060 falls apart in some games at 1440p/4k.
The above video looks more realistic with non throttling vega cards, some of the min framerates on the 2060 at 1440p is![]()
So 50 fps with RTX at ultra. A little rubbish, as my monitor is 75hz. Not exactly a card for 1080p if you want Ray TracingFirst 2060 non Founders Edition review I've seen
https://www.guru3d.com/articles-pages/palit-geforce-rtx-2060-gamingpro-oc-review,1.html
£349.99 @ OCUK if the pricing on the mobile website is indeed correct.
Seems the Ray Tracing needs work for the 2060. Battlefield 5 has very bad performance.
anyone seen kfa2/galax card thats purchasable?
think im likely to get founders as it fits in the case im using the easiest
No way would I want less than 8GB on a card these days.
I've not read this thread but going by frame rate alone is there any net benefit for this as opposed to getting a 1070 TI?
