In fact some of them jumped on it anyway and said gsync wasn't really needed because they couldn't notice tearing![]()
Yer, I remember being told that many times.
I thought I was going free-sync but at the moment it's not looking like the best option. Or even as good an option. My 290x hit's 30fps or lower all the time and that's at 1080p, So if I was to buy the 2560 x 1080 21:9 that has a 40 hz cut off point I'm not going to get a great free-sync experience. I understand why people are gonna claim it's not an issue after having just bought into the tech but it clearly is. It was also highlighted on this forum up to a year ago but ignored and ridiculed by the usual suspects. AMD are in a bad place at the moment, I pray they don't go under and leave us at the mercy of Nvidia.
Yer, I remember being told that many times.![]()
did that peterson guy really say the Swift is under priced?
Yeah but the reason it's smoother is because tearing is gone as well.
It depends on what you believe.
Is it that you believe Free-Sync has a cut off point of 40Hz or have you thought that it may be the display you are looking at?
To save you Googling i will answer that for you.
Free-Sync is capable of operating between 9Hz and 240Hz (9FPS to 240FPS)
If you are looking at a display that cuts Free-Sync off at 40 or less FPS and are not happy with that then you need to be looking at a different display.
No not really the smoothness comes from the frame rate delivery, what you seeing is what you getting..
Tearing isn't a big issue when you have FPS much higher, and 120hz also hides the effect even more so..
No tearing makes for a much smoother image.
No it definitely is really.
Image might look better correct but it dont change how you feel the game, meaning you never feel a tearing in an image.. Having the frame rate given to you at much faster/latency is what is really smoothing out the gameplay. If you felt a screen tear then all them Pro players running 300fps on CSGO much be a stuttering mess![]()
Well done on adding nothing to the discussion.. Same as the couple posts above..
You - yep.. OK add why. Explain
Then post a image of complely out of discussion..
I wasn't talking about high framerates like that, freesync doesn't even work at 300fps...
On a single card in any demanding game you aren't even close to 144fps, tearing appears and when tearing is gone it helps show a smoother image.
You taking about what we see as smooth or what we feel as smooth.. Because seeing and feeling is two different things when it comes to interactive entertainment.
Screen tear would indeed effect how an image looks but it doesn't change how you feel the game.
Who was talking about feeling anything, you're looking at the screen, without tearing it's smoother.
I expected this answer from you anyway as you'll never go back on your word and admit you're wrong.
