- 25 Nov 2011
- The KOP
It is a solution just like turn off your monitor is a solution.
What if someone wants a bright contrasty screen? They will have to put up ghosting until freesync has driver support to mitigate it, or they can use a gsync monitor.
No then they would have a display showing incorrect information. Just like having your brightness over done loosing out of detail in shadows.
A display with correct calibration is a good display.
Simple has that. You choose to over do settings you choose to loose out on detail.
