- 14 May 2012
Not that it fixes the issue at all; but I will be undervolting to around 450W and overclocking back up to around stock levels.
I don't even think demand is especially high its just that the ridiculously low stock levels are panicking people into paying way over the odds.Is there any indication of a better 5080 stock situation in the next month or two? Id actually buy one at or close to msrp but there's absolutely nothing, surely people aren't actually buying them en masse at the current ludicrous pricing. I've a 7900xtx on order because of it ![]()
All this talk of connectors melting etc and people are still waiting to buy them after seeing the FE stock alert on here. Madness
I dont think they are classing the cable that comes with a PSU to be third party, but further clarification would be nice,Isn't every PSU that comes with 12VHPWR connectors/ cables "third party"?
The fact that no one is concerned about all the random old PCIE 8-pin cables that get plugged into the supplied adapters speaks volumes about how crap the design of the 12VHPWR connector is.
12VHPWR cables must be anointed by Nvidia as worthy but the PCIE 8pin cables that we are supposed to plug into the adapters? Those are fine. Plug in any PCIE 8 pin cable from virtually any manufacturer and you're fine.
Buildzoid nailed it when he called the connector "12v high failure rate".
for some of us this is noting newAll this talk of connectors melting etc and people are still waiting to buy them after seeing the FE stock alert on here. Madness
A few people on here that don’t own one have acknowledged itHas nvidia or anyone publicly acknowledged the issue?
I doubt Nvidia will, did they ever with the 40 series?
575W TDP for the 5090 vs 450W for the 4090Also doesn’t the 4090 have a lower tdp AFAIK? Wouldnt that make the 5090 more hazardous?
How did you find this out???5090 FE in stock
Was in stock in Europe only - Not in UK.How did you find this out???
Derbauer's video demonstrated the problem starts from PSU side because the current is inconsistent between each 12V wire 150C at PSU and 90C at GPU. Perhaps the the source split into 4 times more wires will help, plus the 8 pin socket are much more thicker, more contact area, more secure plug altogether. Possibly the GPU socket will still heat up, but maybe it won't be as bad.Doesn't using 4x8pin into the adapters just push all the problems into the adapter, how does it stop the plug into the gpu from melting? I know nothing about how this stuff works.
In my opinion, this is the crux of the problem.
What does true or false have to do with what expectations?Not true. The PSU could be designed to be able to sense the current in each of the six live wires, and to load balance them. It doesn't need to know what its connected to, just the total load request and power going down each live wire.
