some mobos have 2 sockets for cpu for overclocking headroom etcOK now Im confused - why would the CPU need two - there's only one CPU power socket on the motherboard? So should I use the 12vhpwr cable that came with the PSU or not - it says it's ATX 3.0 if that makes any difference? Thanks again for any help
Your 5090 needs 4 so you still don't have enough. So you need to use the dedicated 16pin to 16pin cable that came with your PSU.OK now Im confused - why would the CPU need two - there's only one CPU power socket on the motherboard? So should I use the 12vhpwr cable that came with the PSU or not - it says it's ATX 3.0 if that makes any difference? Thanks again for any help
IIRC it was originally meant to replace having three separate connectors.I really dont understand the point of this new 12 pin power connector.
Since then it seems to have morphed into replacing four connectors and now into replacing the sort of connector/cable you'd find attached to your car battery.
The adapter supplied with your gpu plugging into 4x pci-e cables is probably the least risk involved at this point in time-the only point of melting should be where the GPU power socket connects to the adapter.And Im not running the risk of it melting/bursting into flames if I use the 16 pin thing ? A lot of videos and posts seem pretty alarming and I just want to use my expensive new GPU![]()
8 pin pcie only have 3 pairs. (6 pin originally had 2x12v pins)A laudable aim Im sure but it cant even replace 2 x8pins at the same capacity can it?
2x8pin=16 pins (8 pairs) (and which are larger)
1x 12 pin = 12 pins (6 pairs).
Go back a few pages on here and I've linked the specs of both.Ok my info is slightly wrong as the 8 pin connectors only use 3 pairs for power each.
So 2x 8 pin = 6 power pairs.
1x12 pin = 6 power pairs.
So Im still confused why the 12 pin is considered to be capable of transmitting more power? It doesn't make sense.
Basically the good old 8 pin is capable of 288w but was derated by a lot down to 150w for a bigger safety margin.
The 12v hpwr is capable of 684w but has been rated at 600w. Leaving not much margin for when things do go wrong
Then they could have updated the spec of the 8 pin in the same way?It's rated higher because they've pushed the "on paper" safe limit right up to the theoretical limit.
I opened the SF1000 and it comes with two 8 pin connectors to 1 12V-2x6, there is no marking on the cable to designate H+ or H++.
Absolutely, but there were already low quality adapters, power supplies and cables out there that only meet the 150w requirement. You can't suddenly uprate a connector that's been out there for years.Then they could have updated the spec of the 8 pin in the same way?
You only have to look at the low quality mining risers etc that ignored even that spec and melted easily.
Edit:
As said earlier, why they didn't just make a 16 pin or whatever connector based off the 8 pin connector, god only knows.
