Well, I been talking to cablemod and I will say I was left a bit confused.
According to them, my cable “E-Series Pro ModMesh Sleeved 12VHPWR StealthSense” which I brought for my RTX 4090 FE a few years ago and is completely fine is not the same one you can order through there configurator, he went on to say “12V-2x6 connector features longer pins to ensure proper insertion and reduce the risk of overheating” and my original cable is not recommended.
Now it gets weird, the ones on the shop that are just default ones is the one I have now but was told to use the configurator to select 2x6pin for the 5000 series.
So going by that, the old cable and the ones available on the shop are the older ones but going through there configurator I could select 2x6pin for the 5000 series and is more expensive which I just ordered.
Will use the adapter what is supplied with the card until the new cable turns up around 6 to 8 weeks.
What a complete mess this cable spec is, just go back to the old plugs and be done with it.
The changes to the pin length are on the socket side (on the PSU / GPU), not the cable side (at each end of the cable).
The most important thing for you to identify is whether your PSU has an H+ socket. That’s the thing to ideally avoid using.
If you share the model of your PSU we can help you figure this out.
