NVIDIA RTX 50 SERIES - Technical/General Discussion
Sure, they can't do anything fancy with the voltages but I find it hard to believe the firmware can't drop the power limit to protect itself if it detects an imbalance. Or shut the card down.
I wouldn't be surprised if even the limited monitoring Asus is doing is pushing the limits of what Nvidia find acceptable.
It could be they only got away with it because they're Asus as by monitoring it, and highlighting an issue, they're alluding to it being a problem.
You might be right. Who the hell knows what nonsense Nvidia insist on. Can't have AIBs making a safer card than them. I personally think this tool will cause a lot of grief and support calls for Asus. There could be a lot of 50 series cards that are buzzing away with pins out of spec, not enough to melt and the user is blissfully unaware.
It would be nice if they included some older cards in reviews using the steam hardware survey as a guide. It's nice knowing how current gen cards compare but would also be good to see how older cards compare using more modern CPUs and drivers compared to their original reviews.
Would also let people see how much of upgrade it is.
TPU has a massive relative performance chart that allows you to set any card as the centre point. GN and HUB also include older cards as well as competing cards from a similar tier.
Steam Hardware survey is irrelevant because nobody needs a review to tell them how much better a given card is than a 4060 or 3050 :cry:
Most people have not, rtx5000 is not on steam hardware survey :p
Exactly why all these issues are pretty shocking when there's so few cards out there. Ain't touching this gen with a 10 foot barge pole. Rather not worry about my PC becoming crispy in my house:cry:
It's only because I see comparisons like this using an rtx 4090
Ditto as a 4090 owner. No regrets going from a 7800X3D to 9800X3D. The latest AAA games run like cow dung these days. I can use DLSS performance to lessen the GPU load but I cannot turn down settings to reduce CPU load.
1740496938080-png.386588
5090 Astral running out of spec, taken from the Asus forum. It's so crazy to me that a device that has the ability to regulate its own power draw AND knows it's running out of spec in a way that could cause major hardware failure is just like "Hey, better be quick bucko, cable's about to melt. Do something about? Nah"
Hope you don't miss this OPTIONAL warning while gaming otherwise it's BBQ time.
If I really had to get a 5090 then it would have to be the Astral purely for the current monitoring functionality - and run GPU Tweak on a separate screen to monitor the current draw live while gaming/rendering. Just hope that the app's polling period is sufficient enough and that you just happen to glance at it at the right time.
It's just not worth the risk imo.
