ZOTAC GAMING GeForce RTX 5090 AMP Extreme INFINITY arrived today from other retailer. The card seems pretty solid and well build, I think I could throw it at the wall and it wouldn't bother (but probably would not run anymore so not fancy testing it out
Temporarily hooked it up to my PC with a PCIe rise cable, to check out ROPs, 176 as it should be. Tried a couple of games and they ran like crap, like power draw was around 300W and barely getting as much FPS as a 7900XTX, but that's because I just installed Nvidia driver and that's it. After I removed the 5090 and hooked the 7900XTX back that was also running like garbage.
So it is definitely not recommended to run 2 separate brand drivers on your system. Once I am done with my shift I will properly install the 5090 and DDU isntall Nvidia driver. For now It will be only left air cooled but I got an Alphacool waterblock on the way too.
As for noise, the fan isn't intrusive at all, and the coil whine is 4/10. So it is there, but you'd have to stick your head next to it to make it sound peculiar, with a closed side panel and playing games it's nothing really.
Btw, I ordered PNY 5090 argb triple fan OC, but it was pushed back by another 2 months (so almost May) a few days ago. Then 2 days ago, other retailer sent me an offer via email to trade it in for the ZOTAC GAMING GeForce RTX 5090 AMP Extreme INFINITY, and I said f yeah
