Nvidia’s GameWorks program usurps power from developers, end-users, and AMD
Update (1/3/2014): According to Nvidia, developers can, under certain licensing circumstances, gain access to (and optimize) the GameWorks code, but cannot share that code with AMD for optimization purposes. While we apologize for the error, the net impact remains substantially identical. Game developers are not driver authors and much of the performance optimization for any given title is handled by rapid-fire beta driver releases from AMD or Nvidia in the weeks immediately following a title’s launch. When developers do patch GPU performance directly, it’s often after working with AMD or Nvidia to create the relevant code paths.
http://www.extremetech.com/extreme/...surps-power-from-developers-end-users-and-amd
Following on from this thread, Joel has apologised for the misinformation he previously said.
Just to copy over what i said in the other thread. Good to see Nvidia confessing though and it was nice to finally be proved right in what i said all along since the start. AMD unable to provide their own performance optimizations using their own drivers on any games that use GameWorks code.
Looks like Joel has updated the article (having heard back from Nvidia) and Nvidia have finally fessed up. Lol this is gold!!
Source
So all that crap Joel and i took and Nvidia finally own up. AMD unable to provide their own performance optimizations in THEIR OWN DRIVERS when the game uses GameWorks code.
No matter how you dress it up, it stinks. One side able to optimize, the other not. Thank god not many titles use GameWorks. If ever there is a reason for any respected developer not to use GameWorks code, this is it. If AMD/Mantle ever stopped Nvidia from providing performance optimizations for DX11 then im sure you would be equally as concerned. That's my final say on the matter. Thanks to Frosty for making me check the article again though. Without his prompting i would've missed the Nvidia confession. Its funny because in the other GW thread he kept saying that he needed proof that AMD were not able to optimize their own drivers when using GameWorks code. Well now we have it from the horses mouth that its not possible.
That's my final say on the matter as well. Now Nvidia have confessed, no need for pages of pointless debates going round in circles. I'll leave that to Frosty.
Confessed to what though? They are tight on this new tech, as AMD are with theirs so I don't see what the problem is.
Mantle/DX/GameWorks are all closed libraries, so why is this an issue?
Because Mantle does not block Nvidia from optimizing their own drivers for Mantle capable games that also use DX11.1, ala Battlefield 4/Thief etc. You can't compare GameWorks to Mantle, or even TressFX. TressFX has its own SDK available for download btw.
Mantle and DX are separate code paths and NV can optimize the DX path of a game, mantle does not effect the DX path in any way..
GameWorks is not a separate code path to DX and AMD can not fully optimize for it.
But GameWorks is nVidia tech, so you are getting the GameWorks effects and the optimizations are done via nVidia. You can see from the Batman: Arkham Origins thread how that works for AMD...
Mantle gives older CPU's and GPU's more grunt, so in effect, the equivalent nVidia GPU can't go as high on GFX as a Mantle enabled GPU, so yer, AMD are no better than nVidia with their closed libraries...
Yes if FXAA is used then a 770 is faster than a 290X. Its cause for concern.
100% spot on.
I need to just stop posting here, because even with Nvidia now saying it some just won't accept it and i need to accept that so this will be my last post. Greg don't you try and drag me back in you swine lol. :D
100% spot on.
I accept it and I don't see the issue. Why would you run a game with only FXAA on a 290X? The arguments have always been that when you turn the dials up, then "X" GPU really starts to shine.... Not when you turn the dials down lol
So a GTX 660 is fater than a 7970 with all the settings lowered... Yer ok :rolleyes:
That is a Strawman because Mantle has no effect on how high NV cards can go on gfx settings, Mantle does not effect NV cards, it only effects AMD cards, while GameWorks does effect AMD cards.
It's debatable how much if any performance is lost through GameWorks. AMD cards are **** at tessellation. Look at the Heaven thread for crying out loud. At any point did Joel disable it? Pretty sure he didn't.
There's a line somewhere, and it's not worth the effort trying to find it through all the man-crying about how there is excessive amounts in the particular game.
You stick 8X AA on anything, or most things, and 290s will sail through as they crush Kepler with their extra bandwidth. But turn it on it's head and apparently there's 'too much' tessellation.
Would you like some cheese with that whine.
That is a Strawman because Mentle has no effect on how high NV cards can go on gfx settings, it only effects AMD cards, while GameWorks does effect AMD cards.
No it isn't. My point is perfectly valid. Closed libraries are exactly that and one doesn't counteract the other. I don't care if Mantle is closed, as that is AMD's choice. I don't care if GameWorks is closed, as that is nVidia's choice but all this lambasting of nVidia for doing exactly what AMD are doing is hypocritical.
You can also turn off all of the gameworks options If they were impacting performance, which they aren't
Nvidia have not confessed to anything, that update is from the 3rd of Jan (American date format) and was there for the entirety ofnthe previous arguments
How many people use 290X's or high end gpu's though? A small fraction. How many use low end to mid end gpu's? The majority. So now we have a situation where the majority will be using low to mid range cards and will be using FXAA.
The situation is a 660 is able to beat out a 7950 boost, which is a substantially faster and more expensive card with FXAA on, ala the GameWorks effect. Only when x8 AA is forced (AMD can optimize for AA in the drivers as its not tied to the GW Library - Confirmed by Joel and AMD) can they over power the GW effect. Its a cause for concern if this starts happening in more demanding titles.
660 faster than 7950 boost - 770 faster than 290X (how is that possible???)
x8 AA
The fact that they are both closed is not the point, the point is about optimization in games and with Mantle and DX being separate code paths and as things stand games that use Mantle path also use a DX path so optimization is not an issue for AMD or NV.
But for gameworks that is not the case, optimization is an issue for AMD because there is no separate path.
You explain it better than i can. Now await the incoming deflection. :D
