Warmasice: I flashed my bios to get the lighting card stock speed, then I did a manual overclock, try to get it over 1ghz, but I cant, so 981mhz is the best that I can do with no volts increase. temps 35c idle, 60/65c full load.
Slade, what volts are you running?
Is that on standard bios? Those memory speeds are crazy too!
Is your card running stable at those clocks?
he's asking if you were using the lightening bios or the standard oneHi there,
Was on a standed bios, no flash or anything.... what over bios could i have used? I only set these clocks to do a bench for fun (just wanted to see if my card would go that high). I game @ 980/1480, max volts (1295) using Sapphire Trixx. Cheers![]()
Crysis locks up the card on the stock Lightning bios. I found that out last night.
I switched back to the normal 880 one.
I also had the card switch Windows to basic (no aero) and then shoot to 58c idle. Fans went mad.
Reboot seems to have fixed it for now, but any more issues and I'll RMA it.
Mine just reached 103c in Furmark and that's at 75% fan speed.
Time to reapply paste & reseat the cooler, I have the paste that came with Corsair A50 CPU cooler and Artic Silver 5, which should I use?
I'm currently running 940/1375 @ 1.2v with stock bios.
fans went mad @ 58C? mines idleing around 52c and fans ar spinning at 1375rpm (42% according to Afterburner)
Mine was reaching similar, i'd take it back and let OCUK deal with it, i have voided warranty by reseating mine which is not a massive issue as i'll be watercooling it which will have voided it anyways.Mine just reached 103c in Furmark and that's at 75% fan speed.
Well I have a profile, but it was just totally irrational.
Windows dropped to basic and temps soared. Wouldn't have minded but I was just sitting at MSN minding my own business
If it does it again I will RMA it. I'm not repasting it or taking it apart, that was MSI's job. If they couldn't get that right they can have it back.
No idea. Doesn't matter now though. I found a XFX 7970 for £439 delivered so I ordered that. Mate is buying the Lightning off me![]()
he's asking if you were using the lightening bios or the standard one![]()
Nice one, the XFX one is the one without the bog standard cooler isnt it?
Only problem i have had is that in Crysis the game will crash after playing for like 10 minutes, it will freeze then the screen will go black with fuzzy on the bottom half then crash to desktop with the driver had to restart.
Crysis 1 or 2? Will give it a bash when i get in and see if it does the same on mine
