would you really notice much difference going over 1ghz?
Nah not really. Maybe another 5% over 940. And for the power it consumes and so on it really isn't worth it.
Also, I found that 3DM11 will crash the card before anything else does tbh. It gets a bit blocky then just freezes.
And no, I wouldn't dare putting this firmware on a regular card. You have to remember this is not a stock PCB or card so could be laid out differently?
I don't know man but I wouldn't risk it.
O.K.
When my card was in its stock "Silence" setting I tried to clock it to "Normal" Lightning speeds. This means 940mhz with stock voltage (1174 or what not).
However, when I did it would crash during 3dm11 unless I pushed up the voltage to 1.2v (or 1200mv).
OK.
So today after spending ages looking I finally found a bios dump from an actual Lightning card. This means that at stock clock on the bios the core speed is 940mhz at stock volts.
On the back of your card is a switch. By default it is set to Silence. It has three stages. One click over from Silence is Performance. This, basically, is the second bios on the card for overclocking with and modifying ETC for LN2.
So. I found the bios for the actual lightning (940mhz 1174mv) and flashed it to the second bios that is labelled Performance. If you click to the third setting you will select no bios and the card will not post (mistake on MSI's behalf).
What's odd is that if I clocked the bios that is loaded onto the Silence setting to 940mhz with stock volts it would fail any benchmark or stress test. However, when the actual Lightning bios is loaded onto the card it works perfectly at that clock (940) with stock volts.
You can get the bios from here.
http://www.techsupportforum.com/for...-crap-on-me-when-i-put-load-on-it-570283.html
You need to create an account, but that's no biggie.
Then do the following.
Download something called Radeon Bios editor. The filename for it is RBE_128.exe and I got it from Techpowerup. This will allow you to verify the bios and show the clock speeds and so on.
Then download ATI Winflash. The latest version is 2.0.1.14. Again, that can be downloaded from Techpowerup.
Then download GPUZ.
O.K now shut down the PC.
Find the white switch, and carefully set it one place across. If you go both two places your GPU will not have a bios to load and your PC will just beep like a piggy.
So once you have set it to bios 2 (or Performance) boot your PC.
EDIT. Load GPUZ and back up the bios on there (880mhz)
Load Winflash, flash on the bios in the link I sent you. Reboot when it tells you to.
Load Afterburner, click "reset" at the bottom. Your AB screen should now look like this.
OK, when it looks like that you are now running an actual Lightning bios, stock clock of 940mhz with the stock voltage.
Run 3Dmark11, see if it passes. If it does compare your score comparatively with your rig vs an I7 950 stock clock w 6gb ram.
Pat yourself on the back, 'cos you just made your card worth £50 more![]()
Hows everybody's temps. I idle at 30c and never go over 65c on full load, got HAF-X case, then again my room is like antarctica![]()
I've run same benchmarks... but to scared to play BF3 @ that speed. I'm running 12.1 drivers so not approved by FM apparently.
Heh, sweet
I just went for the 1ghz again but sadly it still isn't stable.
