OcUK LED Light strips!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Here at OcUK we have been playing with some new toys. There are awesome. I will be taking some proper pictures and some video's this evening.
OcUK LED Flexible Lighting Strips 5 Meter (30 LED's per meter) - Red / Green / Blue @ £52.99 inc VAT
Brighten up you life with these amazing LED light strips, ideal for anywhere in your home from the bathroom to you TV/entertainment area, you can even install these under your cupboards and work units in your kitchen.
- 30 LED's per meter
- Reel length: 5meters
- Remoted control for changing settings and switching on/off
- Full Colour LED's lights
- Option to flash between colours / fade between / strobe
- 15 preset colours
- UK Power adapter included
- High Brightness, long life
- Easy Bending
- Cuttable to size
Only £52.99 inc VAT.
ORDER NOW
OcUK LED Flexible Lighting Strips 5 Meter (60 LED's per meter) - Red / Green / Blue @ £64.99 inc VAT
- 60 LED's per meter
- 15 preset colours
- Easy Bending
- Cuttable to size
Only £64.99 inc VAT.
ORDER NOW
OcUK LED Flexible Fully Waterproof Lighting Strips 5 Meter (60 LED's per meter) - Red / Green / Blue @ £69.98 inc VAT
This waterproof kit can even be installed in your bath or hot-tub.
- 15 preset colours
- Easy Bending
- Cuttable to size
Only £69.98 inc VAT.
ORDER NOW
Here is an image of one of the 30 LED per meter strips fitted under kitchen units.
Us playing with our camera with a long stutter speed!
Here are 2 pictures of me spinning the strip to test the robustness :)
And me trying to write my name in lights. (backwards though lol)
And here are 2 pics showing the light strength (which can be adjusted down)
Yes can be cut to length, mains powered. You can solder wires between the cut to leave a gap etc and hide the soldered wire etc. Look at the last pic in blue - see the plug in the wall :)
If they are successful I will be getting additional power bricks etc, as they can be purchased seperately.
Used these for awhile for ambient light behind monitor and TV. Can be cut ever little while. There are cut points on them. There pretty good and can be controlled by Logitech remotes.
You don't do white ones :(
These have a white option on the remote.
Basically each light node has 3 LED's (red, green and blue) they mix together the light to make the different colours.
All three colours = white. These do white, look at the one by last image in my first post.
probably a daft question but what voltage do these run at 12v?
You mean what wattage? I have already tested them with the Energenie Wattage tester we sell. Max wattage it hit was 18watts and that was on full brightness with fastest colour flicker.
I will be doing a more concise review tonight with my power meter :)
no i mean do these run at 240v or 12v at the lights? or is it a 240/12v stepdown transformer?
