OcUK LED Light strips!
Great! How did you program it into the Logitech remote? Did you just use the learning feature or is the LED device listed in the Harmony software?
Anyone else been able to use these LED lights with a Logitech Harmony remote? Which model remote do you have?
Also, if I cut the strip in half, I can't quite grasp what to do in order to power the 2nd strip. Is it just a matter of buying a 2nd power supply and some extra bits or is some soldering/wiring skill needed?
Doubt you will read this but i had a harmony 1. I think i programmed it manually with the learning software.
Any idea how to power these from a molex plug?
