- 16 Nov 2009
- Middlesbrough, UK
Who blamed OcUK / whos crying.. all im saying is that it is not working in my system. Im asking for help...? Get a life
I am using DVI.. but not with the DVI connector I got with it. would this matter?
I dont have another system I can try it in.. Yes its in the blue slot PCIEx16_1 (which is the top slot on my motherboard). Both 6 pin and the 8 pin pci-e power connectors are plugged in. The 8 pin one is just another 6pin one with the 2 extra extension pins you join on the end yes?
There's no need to be so personal this gentleman is trying to help you and all you can do is tell him to go away.
How about you do what has been advised and you might find that your card works.
An attitude like you have is the right one to get you suspended/banned.
