At 5.3GHz you most certainly can!
Hi 1Day
Just a one off. I've settled for 4.5 GHz for daily use and 4.8 GHz for random gaming. Both OC has been stable since yesterday with no lock-up, BSOD's or cold boot issue ussing bios 1204.
Done 8 hrs prime, 20 runs IBT and Linx on both.
Cheers and thanks.
PS
My cousin wants to buy the whole rig off me and i'm thinking about it.![]()
You guys should run IBT custom ram 8 threads 50x
Just wondering what clocks are IBT load temp 24/7 liveable like under 80c IBT load temp.
If people want to run sandy bridge@5Ghz stable, then they should use IBT with 4 threads for i5 2500k and 8 threads for i7 2600k manually set with custom stress level and choosing 'free' memory from windows task manager and then run the program for 50 passes. Check your GFlops values and coretemps![]()
Bios 1090 for Maximus IV Extreme? The latest on the ASUS website is 09015.43Ghz New bios 1090 is a lot better with my G.skills!
It's certainly not that easy with a 2500k. Not whilst staying below the 1.4V vcore guideline anyway.
I'm still tempted to try and top the 2500k list but I'd probably want to cry if I fried the chip and couldn't afford the downtime waiting for an RMA.
Also is there any way you could share your settings for that? I haven't started overclocking my SB yet and would appreciate something to compare against.
Thanks!
