nope, brick wall after 2133MHz i can get 2200MHz but i gave to up the bclk to 103.2
anything after 2133MHz using IMC will not boot even 13-13-13-35-2T
What Q-Code?? Samsung Green??
yer sammy green, although i have now found out i can get 2400MHz but only at 11-11-11-35-1t and very loose secondary timings!
8Pack can you please post what cooling you are using with each submission. I am worried that someone will try to copy your voltages while not having your cooling.
I must comment that although 8Packs scores are mighty impressive he is using serious cooling i.e. Freon at -100c or better. We mortals cannot, and should not try to compete.
i have a 3770k, ive made it to 5.2ghz but cannot find a suitable voltage for a higher clock. Can anyone reccomend me what voltages to use at a higher overclock then this, any table with a list or somthing. Thanks
I was at Cas 9 at 2400mhz. Thats really strange. What board???
asrock z77e-itx i cant play with thirds
Hiviz is a friend and the UK's number one!!!
